Line in for 41-285
Thanks.
Instead of wiring in a 1-2 switch, could I do something along the lines of adding some large resistance to the adapter? It uses 10 ohm resistors as built; Would I be better off putting larger ones in and if so, what size? 5K? 10K?
Thank you!
Line in for 41-285 - by Diverted - 02-14-2014, 04:55 PM
RE: Line in for 41-285 - by morzh - 02-14-2014, 05:25 PM
RE: Line in for 41-285 - by Diverted - 02-14-2014, 05:40 PM
RE: Line in for 41-285 - by morzh - 02-14-2014, 05:47 PM
RE: Line in for 41-285 - by Diverted - 02-16-2014, 05:40 PM
RE: Line in for 41-285 - by morzh - 02-16-2014, 05:59 PM
There are currently 9798 online users. [Complete List]
» 3 Member(s) | 9795 Guest(s)
