Two Philcos
It is not necessarily a question of performance. At least for me. Like this TPA-1 portable player - well, sound-quality-wise it is a POC, but then it is the first ever all-transistor portable.
20 is the first Baby Grand. I want to have it in my collection and it should work. But I will sure listen to 37-116 more than I will to 20.
Two Philcos - by Section10 - 02-10-2014, 05:31 PM
RE: Two Philcos - by tab10672 - 02-10-2014, 10:34 PM
RE: Two Philcos - by morzh - 02-10-2014, 10:59 PM
RE: Two Philcos - by klondike98 - 02-10-2014, 11:17 PM
RE: Two Philcos - by GarySP - 02-11-2014, 01:28 PM
RE: Two Philcos - by morzh - 02-11-2014, 02:24 PM
RE: Two Philcos - by SteveJB - 02-11-2014, 04:25 PM
RE: Two Philcos - by 37silverstreak - 02-11-2014, 08:40 PM
RE: Two Philcos - by Radioroslyn - 02-13-2014, 06:06 PM
RE: Two Philcos - by GarySP - 02-14-2014, 06:14 PM
RE: Two Philcos - by morzh - 02-14-2014, 06:22 PM
RE: Two Philcos - by Section10 - 02-16-2014, 08:53 AM
RE: Two Philcos - by Mondial - 02-16-2014, 12:36 PM
RE: Two Philcos - by Section10 - 02-16-2014, 02:37 PM
RE: Two Philcos - by PhilcoJohn - 02-16-2014, 04:33 PM
There are currently 8406 online users. [Complete List]
» 1 Member(s) | 8405 Guest(s)
