cap questions on model 89 (version 6 schematic)
The cap going to resistor 41 should be a .05
RE: cap questions on model 89 (version 6 schematic) - by tab10672 - 02-15-2014, 02:59 AM
Philco 91 Tuning Condenser
There are currently 5307 online users. [Complete List]
» 3 Member(s) | 5304 Guest(s)
