Philco model 70 rebuild - by Tim P.
Threads: 562
Tim,
Good, it is alive.
Next time MAKE IT A RULE to test all tube before putting them in: you got off cheap compared to what could have happened.
Now, looks like you could use an alignment.
Surprisingly mine works just fine ( no it does not justofy no alignment and it will be done) despite the rewound coil ( I did dnot expect that coil to influence alignment but still).
As for the volume pot, I sprayed Deoxit right into the leads' rivets' holes, liberally....no scratching anymore.
RE: Philco model 70 rebuild - by Tim P. - by morzh - 02-15-2014, 04:45 PM
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 10239 online users. [Complete List] » 1 Member(s) | 10238 Guest(s)
