Model 89...a quick, easy question
Hopefully someone who owns one will chime in and confirm.
Gregb
RE: Model 89...a quick, easy question - by gregb - 02-15-2014, 09:11 PM
RE: Model 89...a quick, easy question - by gregb - 02-15-2014, 09:31 PM
Philco 91 Tuning Condenser
