Model 89...a quick, easy question
The first click is the broadcast band. The contacts will be open on broadcast.
M R Radios   C M Tubes
RE: Model 89...a quick, easy question - by gregb - 02-15-2014, 09:11 PM
RE: Model 89...a quick, easy question - by gregb - 02-15-2014, 09:31 PM
RE: Model 89...a quick, easy question - by Steve Davis - 02-15-2014, 09:52 PM
Philco 91 Tuning Condenser
