  • 1 Vote(s) - 5 Average
Philco 70 restoration attempt - singing now.
#38
Did the alignment a couple of hours ago.
Wow.....this thing is sen-see-teeeve, with 2 feet of wire for aerial it pulls in tons of stations, every 2-3 degrees of rotation pull another one.
RE: Philco 70 restoration attempt. - by morzh - 01-24-2014, 10:53 PM
RE: Philco 70 restoration attempt. - by morzh - 01-25-2014, 12:00 AM
RE: Philco 70 restoration attempt. - by morzh - 01-25-2014, 12:59 AM
RE: Philco 70 restoration attempt. - by Jamesm - 01-25-2014, 11:57 AM
RE: Philco 70 restoration attempt. - by gregb - 01-25-2014, 03:50 PM
RE: Philco 70 restoration attempt. - by morzh - 01-25-2014, 07:28 PM
RE: Philco 70 restoration attempt. - by morzh - 01-25-2014, 09:13 PM
RE: Philco 70 restoration attempt. - by Mondial - 01-26-2014, 12:28 AM
RE: Philco 70 restoration attempt. - by gregb - 01-26-2014, 12:40 AM
RE: Philco 70 restoration attempt. - by morzh - 01-26-2014, 02:57 PM
RE: Philco 70 restoration attempt. - by Raleigh - 01-27-2014, 02:12 PM
RE: Philco 70 restoration attempt. - by morzh - 01-27-2014, 02:46 PM
RE: Philco 70 restoration attempt. - by morzh - 01-31-2014, 10:10 PM
RE: Philco 70 restoration attempt. - by morzh - 01-31-2014, 10:11 PM
RE: Philco 70 restoration attempt. - by TV MAN - 02-01-2014, 01:20 PM
RE: Philco 70 restoration attempt. - by morzh - 02-01-2014, 01:53 PM
RE: Philco 70 restoration attempt. - by morzh - 02-01-2014, 11:27 PM
RE: Philco 70 restoration attempt. - by morzh - 02-01-2014, 11:39 PM
RE: Philco 70 restoration attempt. - by morzh - 02-02-2014, 09:12 PM
RE: Philco 70 restoration attempt. - by morzh - 02-02-2014, 09:25 PM
RE: Philco 70 restoration attempt. - by morzh - 02-03-2014, 09:32 PM
RE: Philco 70 restoration attempt. - by morzh - 02-05-2014, 01:04 PM
RE: Philco 70 restoration attempt. - by morzh - 02-06-2014, 09:03 PM
RE: Philco 70 restoration attempt. - by morzh - 02-07-2014, 04:52 PM
RE: Philco 70 restoration attempt. - by murf - 02-08-2014, 03:15 PM
RE: Philco 70 restoration attempt. - by morzh - 02-08-2014, 03:41 PM
RE: Philco 70 restoration attempt. - by TV MAN - 02-08-2014, 03:41 PM
RE: Philco 70 restoration attempt. - by morzh - 02-08-2014, 03:49 PM
RE: Philco 70 restoration attempt. - by morzh - 02-10-2014, 10:37 PM
RE: Philco 70 restoration attempt. - by TV MAN - 02-11-2014, 12:16 PM
RE: Philco 70 restoration attempt. - by morzh - 02-11-2014, 12:27 PM
RE: Philco 70 restoration attempt. - by morzh - 02-13-2014, 09:48 PM
RE: Philco 70 restoration attempt - singing now. - by morzh - 02-15-2014, 11:58 PM
The speaker table error?
Philco 70 antenna lead
