70/90 knobs
You are right, they are indeed the same size. It seemed like it was not, maybe due to the size of the knob.
70/90 knobs - by morzh - 02-16-2014, 06:28 PM
RE: 70/90 knobs - by tab10672 - 02-16-2014, 06:34 PM
RE: 70/90 knobs - by morzh - 02-16-2014, 06:48 PM
RE: 70/90 knobs - by skyscraper - 02-16-2014, 07:55 PM
RE: 70/90 knobs - by morzh - 02-16-2014, 08:05 PM
RE: 70/90 knobs - by tab10672 - 02-16-2014, 08:49 PM
RE: 70/90 knobs - by morzh - 02-16-2014, 09:37 PM
RE: 70/90 knobs - by TA Forbes - 02-18-2014, 12:42 PM
RE: 70/90 knobs - by morzh - 02-18-2014, 01:12 PM
Philco 91 Tuning Condenser
