Philco 37-660 Hum
Gm
Did not do a full recap but did find issue- neg of 8uF electro caps was on chassis- once corrected now functions as should. I also as a precaution checked all tubes and all tested in tolerance.
Thank all for assist and direction!
Philco 37-660 Hum - by mgambuzza - 02-15-2014, 02:18 AM
RE: Philco 37-660 Hum - by gregb - 02-15-2014, 01:03 PM
RE: Philco 37-660 Hum - by morzh - 02-15-2014, 01:20 PM
RE: Philco 37-660 Hum - by mgambuzza - 02-15-2014, 04:52 PM
RE: Philco 37-660 Hum - by morzh - 02-15-2014, 04:56 PM
RE: Philco 37-660 Hum - by mgambuzza - 02-17-2014, 08:31 AM
RE: Philco 37-660 Hum - by morzh - 02-17-2014, 12:47 PM
Philco 91 Tuning Condenser
There are currently 4632 online users. [Complete List]
» 2 Member(s) | 4630 Guest(s)
