Philco model 70 rebuild - by Tim P.
Threads: 562
Tim, a pot is a pot is a pot, so as long as you see where the whiper is, it all that matters.
If you need help with that let me know.
RE: Philco model 70 rebuild - by Tim P. - by morzh - 02-17-2014, 12:45 PM
Users browsing this thread: 27 Guest(s)
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 11323 online users. [Complete List] » 2 Member(s) | 11321 Guest(s)
