Philco 84B Restoration Chronicles DONE
I have replaced all the bad veneer that was on the cabinet and am now in the stripping process.
This is my current pile of radios. Icon_lolIcon_crazyIcon_mrgreen
RE: Philco 84B Restoration Chronicles - by OldRestorer - 02-17-2014, 02:57 PM
RE: Philco 84B Restoration Chronicles - by morzh - 04-08-2014, 10:31 PM
RE: Philco 84B Restoration Chronicles - by Geoff - 04-14-2014, 12:36 PM
There are currently 9518 online users. [Complete List]
» 1 Member(s) | 9517 Guest(s)
