Philco 76-1134 Antenna Coupler (three prong)
See posts #3 and #5 above, where Stephen Masek found the mica cap to be 6 pF and measured the coil at 0.292 mH.
RE: Philco 76-1134 Antenna Coupler (three prong) - by Ron Ramirez - 02-17-2014, 05:08 PM
Philco 91 Tuning Condenser
There are currently 9771 online users. [Complete List]
» 1 Member(s) | 9770 Guest(s)
