Philco 30 lowboy
For what its worth, I have a 95 with the same tapestry cloth that was badly faded so I bought a set of sharpie fine point markers (the set walmart sells with about 50 different colors) and since the cloth is embroidered the thread is raised so much that you can color in the high stitches to bring it back to life.
Philco 30 lowboy - by Jayce - 11-11-2013, 08:09 PM
RE: Philco 30 lowboy - by jerryhawthorne - 11-11-2013, 10:23 PM
RE: Philco 30 lowboy - by Jayce - 02-17-2014, 05:52 PM
RE: Philco 30 lowboy - by jerryhawthorne - 02-17-2014, 06:14 PM
RE: Philco 30 lowboy - by tab10672 - 02-17-2014, 07:10 PM
RE: Philco 30 lowboy - by Jayce - 02-17-2014, 07:23 PM
RE: Philco 30 lowboy - by Radioroslyn - 02-17-2014, 11:59 PM
RE: Philco 30 lowboy - by Ron Ramirez - 02-18-2014, 06:51 AM
RE: Philco 30 lowboy - by TA Forbes - 02-18-2014, 12:35 PM
RE: Philco 30 lowboy - by Jayce - 02-18-2014, 05:54 PM
RE: Philco 30 lowboy - by Jayce - 04-08-2014, 02:57 PM
RE: Philco 30 lowboy - by TA Forbes - 04-09-2014, 10:40 AM
RE: Philco 30 lowboy - by Arran - 04-11-2014, 10:16 PM
Philco 91 Tuning Condenser
There are currently 9431 online users. [Complete List]
» 1 Member(s) | 9430 Guest(s)
