Need Help With 46-200
Anthony Knoll Wrote:Hello Everyone,
I am new to this forum and am restoring my first tube radio, a Philco Transitone 46-200. I have replaced all the capacitors with new equivalents and replaced the bad tubes. The radio lights up, but only picks up one station at a very very low volume. If I giggle the original antena the station fades out completely. I tried attaching a modern antenna and as well as cleaning and re soldering the leads to the original and only got nothing. Any advice or theories to correct this problem would be most appreciated.
Thank you,
Anthony Knoll
I have no experience with this model radio, but by looking at the schematic the original antenna should have 3.2 ohms resistance. Does it? Also the external antenna connection is shown as grounded when using the built in antenna, is it? If this all checks out maybe the alignment is way off. Have you aligned the radio?
Bill
It's not what you don't know that hurts you it's what you know that's not so.
Need Help With 46-200 - by Guest - 06-29-2008, 11:21 PM
Re: Need Help With 46-200 - by wonderwrench - 06-30-2008, 12:54 AM
[No subject] - by rghines1 - 06-30-2008, 10:41 AM
[No subject] - by gary rabbitt - 07-06-2008, 11:50 PM
There are currently 10493 online users. [Complete List]
» 1 Member(s) | 10492 Guest(s)
