4 Radio cabinets finished in one day!
Well, With it falling and breaking right after I put it all back together I will re strip and grain fill.
RE: 4 Radio cabinets finished in one day! - by OldRestorer - 02-18-2014, 08:02 AM
Philco 91 Tuning Condenser
There are currently 9333 online users. [Complete List]
» 2 Member(s) | 9331 Guest(s)
