Philco model 70 rebuild - by Tim P.
Threads: 562
It should be so sensitive you moving your hand anywhere near the RF coil should make the radio scream.
Look at your antenna coils.
Check the whole circuit. Maybe your tuning capacitor is not soldered or something.
Also your volume pot could do a number on it.
You did check all tubes, right?
RE: Philco model 70 rebuild - by Tim P. - by morzh - 02-18-2014, 11:44 AM
Users browsing this thread: 30 Guest(s)
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 10343 online users. [Complete List] » 3 Member(s) | 10340 Guest(s)
