4 Radio cabinets finished in one day!
Ugh......almost hurts to look at it.
That ever happens to me, I will probably empty a bottle of something 80 proof.....
RE: 4 Radio cabinets finished in one day! - by morzh - 02-18-2014, 11:47 AM
Philco 91 Tuning Condenser
There are currently 9216 online users. [Complete List]
» 1 Member(s) | 9215 Guest(s)
