Need Help With 46-200
Verify your local oscillator is running too. Pin 4 of your 7A8 tube should be several volts negative if it is working, if not read zero.
Recommended you make basic voltage checks such as the B+ supply and the various tubes pins to be sure they are close.
Richard
Need Help With 46-200 - by Guest - 06-29-2008, 11:21 PM
Re: Need Help With 46-200 - by wonderwrench - 06-30-2008, 12:54 AM
[No subject] - by rghines1 - 06-30-2008, 10:41 AM
[No subject] - by gary rabbitt - 07-06-2008, 11:50 PM
There are currently 4363 online users. [Complete List]
» 4 Member(s) | 4359 Guest(s)
AvatarAvatarAvatarAvatar
