Philco 16B CL find
Thanks. I am happy that the chassis is original also except for two e-caps.
The walnut is in nice shape too, just the toner is flaking all over. I need to find out what color to use there. All in all an easy (it appears) restoration.
Philco 16B CL find - by SteveJB - 02-16-2014, 05:50 PM
RE: Philco 16B CL find - by morzh - 02-16-2014, 05:58 PM
RE: Philco 16B CL find - by SteveJB - 02-16-2014, 06:03 PM
RE: Philco 16B CL find - by Jayce - 02-16-2014, 06:03 PM
RE: Philco 16B CL find - by TA Forbes - 02-18-2014, 12:38 PM
RE: Philco 16B CL find - by SteveJB - 02-18-2014, 04:51 PM
RE: Philco 16B CL find - by Art Hoch - 03-04-2014, 08:01 PM
RE: Philco 16B CL find - by SteveJB - 03-05-2014, 02:11 AM
RE: Philco 16B CL find - by PhilcoJohn - 03-05-2014, 08:44 AM
RE: Philco 16B CL find - by SteveJB - 03-05-2014, 10:37 AM
Philco 91 Tuning Condenser
There are currently 9826 online users. [Complete List]
» 1 Member(s) | 9825 Guest(s)
