Philco 39-116
It will be fairly intense. Even for an experienced guy. But...not impossible.
Philco 39-116 - by fields 100 - 02-19-2014, 12:35 AM
RE: Philco 39-116 - by morzh - 02-19-2014, 12:37 AM
RE: Philco 39-116 - by TA Forbes - 02-19-2014, 12:38 AM
RE: Philco 39-116 - by fields 100 - 02-21-2014, 12:47 PM
RE: Philco 39-116 - by gregb - 02-21-2014, 12:58 PM
RE: Philco 39-116 - by morzh - 02-21-2014, 01:38 PM
RE: Philco 39-116 - by Arran - 02-21-2014, 11:05 PM
RE: Philco 39-116 - by gregb - 02-21-2014, 11:17 PM
RE: Philco 39-116 - by fields 100 - 02-21-2014, 11:34 PM
RE: Philco 39-116 - by Arran - 02-22-2014, 04:22 AM
Philco 91 Tuning Condenser
