philco turntable for model 47 1230
I have posted this message as part of a larger thread but thought it good idea to post it separately as well. I would like to complete the restoration of my friends grandfathers philco 47 1230 by installing a record player....The original is missing. I know that the original was only capable of playing 78rpm records and would like to install something that can play 33s and 45s as well....is there a replacement that someone can recommend that would fit right in, attaching to all fo the conections without having to rewire the entire radio (which is beyond me)....thanks Victor
philco turntable for model 47 1230 - by victor3d - 02-19-2014, 11:09 AM
There are currently 7138 online users. [Complete List]
» 1 Member(s) | 7137 Guest(s)
