philco 71h severed RF coil winding
Hello. Brand new to the forum and hope that some of you folks can help me out.
First off i have no experience in testing coils, and i know i have alot to learn yet. But looking over the chassis of the 71h i see that the single wire that runs up from the inner RF coil length and attaches to a lug is severed. I have decent soldering skills therefore i'm wondering if i could just solder a piece of 32 gauge wire to repair it? Or would this throw the coil out of wack? If this isnt possible where could one find a replacement coil? Part # is 04339. thanks in advance.!
philco 71h severed RF coil winding - by dirkbuddy - 02-19-2014, 11:24 PM
RE: philco 71h severed RF coil winding - by morzh - 03-08-2014, 06:34 PM
RE: philco 71h severed RF coil winding - by morzh - 03-08-2014, 10:36 PM
RE: philco 71h severed RF coil winding - by morzh - 03-08-2014, 11:35 PM
RE: philco 71h severed RF coil winding - by morzh - 03-09-2014, 11:27 AM
RE: philco 71h severed RF coil winding - by morzh - 06-11-2014, 03:29 PM
There are currently 10103 online users. [Complete List]
» 1 Member(s) | 10102 Guest(s)
