Philco 16B toner color
Spray it with clear laquer then sand to a smooth finish. then spray the color and a couple more coats of clear over that.
Philco 16B toner color - by SteveJB - 02-19-2014, 06:18 PM
RE: Philco 16B toner color - by Warren - 02-19-2014, 07:22 PM
RE: Philco 16B toner color - by SteveJB - 02-19-2014, 11:11 PM
RE: Philco 16B toner color - by Warren - 02-20-2014, 12:49 AM
RE: Philco 16B toner color - by Ron Ramirez - 02-20-2014, 08:15 AM
RE: Philco 16B toner color - by SteveJB - 02-20-2014, 08:47 AM
RE: Philco 16B toner color - by Ron Ramirez - 02-20-2014, 08:52 AM
RE: Philco 16B toner color - by SteveJB - 02-20-2014, 09:30 PM
RE: Philco 16B toner color - by SteveJB - 02-21-2014, 08:36 AM
RE: Philco 16B toner color - by Ron Ramirez - 02-21-2014, 08:39 AM
RE: Philco 16B toner color - by OldRestorer - 02-27-2014, 10:47 AM
RE: Philco 16B toner color - by Art Hoch - 03-05-2014, 10:42 PM
RE: Philco 16B toner color - by Jamie - 03-08-2014, 03:05 PM
Philco 91 Tuning Condenser
There are currently 10187 online users. [Complete List]
» 2 Member(s) | 10185 Guest(s)
