Philco 16B toner color
You need Extra Dark Walnut - the Mohawk Ultra Classic, not the Tone Finish if you want any grain to show through - for an authentic finish color. Medium Walnut on the raised panels in front. For the lines above and below the PHILCO decal and in the grille bars, you might be able to find some nail polish in the proper shade of ivory. Careful work with the nail polish will result in a near-factory appearance.
Philco 16B toner color - by SteveJB - 02-19-2014, 06:18 PM
RE: Philco 16B toner color - by Warren - 02-19-2014, 07:22 PM
RE: Philco 16B toner color - by SteveJB - 02-19-2014, 11:11 PM
RE: Philco 16B toner color - by Warren - 02-20-2014, 12:49 AM
RE: Philco 16B toner color - by Ron Ramirez - 02-20-2014, 08:15 AM
RE: Philco 16B toner color - by SteveJB - 02-20-2014, 08:47 AM
RE: Philco 16B toner color - by Ron Ramirez - 02-20-2014, 08:52 AM
RE: Philco 16B toner color - by SteveJB - 02-20-2014, 09:30 PM
RE: Philco 16B toner color - by SteveJB - 02-21-2014, 08:36 AM
RE: Philco 16B toner color - by Ron Ramirez - 02-21-2014, 08:39 AM
RE: Philco 16B toner color - by OldRestorer - 02-27-2014, 10:47 AM
RE: Philco 16B toner color - by Art Hoch - 03-05-2014, 10:42 PM
RE: Philco 16B toner color - by Jamie - 03-08-2014, 03:05 PM
Philco 91 Tuning Condenser
There are currently 10222 online users. [Complete List]
» 3 Member(s) | 10219 Guest(s)
