philco 71h severed RF coil winding
Welcome to the forum, Dirk.
It's good to have you !
Kenneth
philco 71h severed RF coil winding - by dirkbuddy - 02-19-2014, 11:24 PM
RE: philco 71h severed RF coil winding - by Richmond Designs - 02-20-2014, 03:32 PM
RE: philco 71h severed RF coil winding - by morzh - 03-08-2014, 06:34 PM
RE: philco 71h severed RF coil winding - by morzh - 03-08-2014, 10:36 PM
RE: philco 71h severed RF coil winding - by morzh - 03-08-2014, 11:35 PM
RE: philco 71h severed RF coil winding - by morzh - 03-09-2014, 11:27 AM
RE: philco 71h severed RF coil winding - by morzh - 06-11-2014, 03:29 PM
