Philco 16B toner color
Sorry, I have one more question.
I looked at the color chart for the Ultra Classic and they seems much lighter for both the Extra Dark Walnut and Medium Dark Walnut than the tone finish versions (which look a closer match to me). I am looking at it on a laptop, maybe the colors aren't coming through that way they should?
My finish seems original, and there is little if any grain showing. I am trying to match without stripping only where the edges are flaked. Would the Ultra Classic be that dark?
Philco 16B toner color - by SteveJB - 02-19-2014, 06:18 PM
RE: Philco 16B toner color - by Warren - 02-19-2014, 07:22 PM
RE: Philco 16B toner color - by SteveJB - 02-19-2014, 11:11 PM
RE: Philco 16B toner color - by Warren - 02-20-2014, 12:49 AM
RE: Philco 16B toner color - by Ron Ramirez - 02-20-2014, 08:15 AM
RE: Philco 16B toner color - by SteveJB - 02-20-2014, 08:47 AM
RE: Philco 16B toner color - by Ron Ramirez - 02-20-2014, 08:52 AM
RE: Philco 16B toner color - by SteveJB - 02-20-2014, 09:30 PM
RE: Philco 16B toner color - by SteveJB - 02-21-2014, 08:36 AM
RE: Philco 16B toner color - by Ron Ramirez - 02-21-2014, 08:39 AM
RE: Philco 16B toner color - by OldRestorer - 02-27-2014, 10:47 AM
RE: Philco 16B toner color - by Art Hoch - 03-05-2014, 10:42 PM
RE: Philco 16B toner color - by Jamie - 03-08-2014, 03:05 PM
Philco 91 Tuning Condenser
There are currently 10101 online users. [Complete List]
» 2 Member(s) | 10099 Guest(s)
