Philco 38-690 electrolytic capacitors--UPDATE
I do have a tube tester. The tubes in the power supply test OK. I haven't tested any of the tubes in the chassis yet but I did make sure they were all seated in the sockets before I slowly powered up the set.
I got this set from Willie in PA and he has a good reputation. I suspect something happened during shipping but at this point nothing is obvious.
RE: Philco 38-690 electrolytic capacitors - by retiredinprescott - 02-21-2014, 10:40 AM
