Record player start-stop switch
Does someone have an electric phonograph with the start-stop switch controlled by the tone arm - when you move tonearm away from the disk it starts and when it reaches the center it stops.
Tim and I need a photo - preferably with the switch shown in end positions. The switch is made of a steel wire flip-flopping a conductive roller that closes/open the contacts.
For that matter, are there any Radiomuseum members?
They have service manual.
This one.
http://www.radiomuseum.org/r/philco_tpa_1_tpa1.html
Need that page that has the mechanics shown.
Record player start-stop switch - by morzh - 02-21-2014, 02:33 PM
There are currently 8565 online users. [Complete List]
» 1 Member(s) | 8564 Guest(s)
