What did I win?
Tim how do the radios perform? I have one in my living room waiting to be restored. Hope they work good and pull in stations across the dial!
What did I win? - by TimC - 01-28-2014, 06:43 PM
RE: What did I win? - by OldRestorer - 01-28-2014, 07:01 PM
RE: What did I win? - by TimC - 01-28-2014, 07:14 PM
RE: What did I win? - by jontz - 01-28-2014, 08:11 PM
RE: What did I win? - by Eric T - 01-28-2014, 09:34 PM
RE: What did I win? - by TimC - 01-28-2014, 09:43 PM
RE: What did I win? - by morzh - 01-28-2014, 10:43 PM
RE: What did I win? - by Art Hoch - 02-03-2014, 08:30 PM
RE: What did I win? - by TimC - 02-03-2014, 09:17 PM
RE: What did I win? - by TimC - 02-21-2014, 04:16 PM
RE: What did I win? - by PhilcoJohn - 02-21-2014, 07:02 PM
RE: What did I win? - by TimC - 02-21-2014, 07:45 PM
Philco 91 Tuning Condenser
