40-180 tube information
have a 40-180 and the tubes that are in it in some cases do not match the schematic det osc on schematic is 7j7 tube in chassis is cj8g can't find out if thats a sub or not, any suggestiions?
40-180 tube information - by mountain man - 02-21-2014, 09:34 PM
RE: 40-180 tube information - by morzh - 02-21-2014, 09:43 PM
RE: 40-180 tube information - by DeckApe - 02-21-2014, 09:48 PM
RE: 40-180 tube information - by murf - 02-21-2014, 10:29 PM
RE: 40-180 tube information - by morzh - 02-21-2014, 10:31 PM
RE: 40-180 tube information - by Joeztech - 02-25-2014, 09:44 PM
There are currently 10277 online users. [Complete List]
» 2 Member(s) | 10275 Guest(s)
