Canadian 345 Butterfly
Only needed cleaning, that's the one nice thing about radio collecting in western Canada. We don't have many radios but the ones we do have tend to have nice clean rust free chassis. Its very dry here and rust is something I don't usually see unless the radio was stored outside.
Gregb
Canadian 345 Butterfly - by gregb - 02-21-2014, 09:51 PM
RE: Canadian 345 Butterfly - by morzh - 02-21-2014, 09:57 PM
RE: Canadian 345 Butterfly - by murf - 02-21-2014, 10:23 PM
RE: Canadian 345 Butterfly - by morzh - 02-21-2014, 10:28 PM
RE: Canadian 345 Butterfly - by gregb - 02-21-2014, 10:42 PM
RE: Canadian 345 Butterfly - by morzh - 02-21-2014, 10:49 PM
RE: Canadian 345 Butterfly - by Mondial - 02-21-2014, 11:01 PM
RE: Canadian 345 Butterfly - by gregb - 02-21-2014, 11:03 PM
RE: Canadian 345 Butterfly - by klondike98 - 02-21-2014, 11:06 PM
RE: Canadian 345 Butterfly - by gregb - 02-21-2014, 11:09 PM
RE: Canadian 345 Butterfly - by gregb - 02-21-2014, 11:10 PM
RE: Canadian 345 Butterfly - by Mondial - 02-21-2014, 11:32 PM
RE: Canadian 345 Butterfly - by klondike98 - 02-21-2014, 11:42 PM
RE: Canadian 345 Butterfly - by gregb - 02-21-2014, 11:43 PM
RE: Canadian 345 Butterfly - by Arran - 02-21-2014, 11:45 PM
RE: Canadian 345 Butterfly - by klondike98 - 02-21-2014, 11:53 PM
RE: Canadian 345 Butterfly - by gregb - 02-22-2014, 12:01 AM
RE: Canadian 345 Butterfly - by klondike98 - 02-22-2014, 12:07 AM
RE: Canadian 345 Butterfly - by Arran - 02-22-2014, 12:45 AM
RE: Canadian 345 Butterfly - by morzh - 02-22-2014, 12:52 AM
RE: Canadian 345 Butterfly - by gregb - 02-22-2014, 12:55 AM
RE: Canadian 345 Butterfly - by gregb - 02-22-2014, 01:03 AM
RE: Canadian 345 Butterfly - by Arran - 02-22-2014, 01:04 AM
RE: Canadian 345 Butterfly - by morzh - 02-22-2014, 12:53 PM
There are currently 10583 online users. [Complete List]
» 2 Member(s) | 10581 Guest(s)
