Philco 38-690 electrolytic capacitors--UPDATE
I used 450v e-caps for all on mine. It has been playing great about two years now. No problems.
Make sure you don't try re-stuff the 10kc bakelite filter coil by mistake. It is in the same type housing as the standard Philco bakelite caps. Hard to tell, so be sure you are cleaning out a block capacitor and not the coil. Most of the other caps are paper as you have already seen.
RE: Philco 38-690 electrolytic capacitors - by SteveJB - 02-21-2014, 11:19 PM
There are currently 4976 online users. [Complete List]
» 1 Member(s) | 4975 Guest(s)
