Canadian 345 Butterfly
Arran, thanks for the tip of the cardboard wrapping as a shim. I've been placing a new cap into the tube and using a glue gun also, but without the shim its a bit of a balancing act to get the leads in the center while the glue cools.
Canadian 345 Butterfly - by gregb - 02-21-2014, 09:51 PM
RE: Canadian 345 Butterfly - by morzh - 02-21-2014, 09:57 PM
RE: Canadian 345 Butterfly - by murf - 02-21-2014, 10:23 PM
RE: Canadian 345 Butterfly - by morzh - 02-21-2014, 10:28 PM
RE: Canadian 345 Butterfly - by gregb - 02-21-2014, 10:42 PM
RE: Canadian 345 Butterfly - by morzh - 02-21-2014, 10:49 PM
RE: Canadian 345 Butterfly - by Mondial - 02-21-2014, 11:01 PM
RE: Canadian 345 Butterfly - by gregb - 02-21-2014, 11:03 PM
RE: Canadian 345 Butterfly - by klondike98 - 02-21-2014, 11:06 PM
RE: Canadian 345 Butterfly - by gregb - 02-21-2014, 11:09 PM
RE: Canadian 345 Butterfly - by gregb - 02-21-2014, 11:10 PM
RE: Canadian 345 Butterfly - by Mondial - 02-21-2014, 11:32 PM
RE: Canadian 345 Butterfly - by klondike98 - 02-21-2014, 11:42 PM
RE: Canadian 345 Butterfly - by gregb - 02-21-2014, 11:43 PM
RE: Canadian 345 Butterfly - by Arran - 02-21-2014, 11:45 PM
RE: Canadian 345 Butterfly - by klondike98 - 02-21-2014, 11:53 PM
RE: Canadian 345 Butterfly - by gregb - 02-22-2014, 12:01 AM
RE: Canadian 345 Butterfly - by klondike98 - 02-22-2014, 12:07 AM
RE: Canadian 345 Butterfly - by Arran - 02-22-2014, 12:45 AM
RE: Canadian 345 Butterfly - by morzh - 02-22-2014, 12:52 AM
RE: Canadian 345 Butterfly - by gregb - 02-22-2014, 12:55 AM
RE: Canadian 345 Butterfly - by gregb - 02-22-2014, 01:03 AM
RE: Canadian 345 Butterfly - by Arran - 02-22-2014, 01:04 AM
RE: Canadian 345 Butterfly - by morzh - 02-22-2014, 12:53 PM
There are currently 10534 online users. [Complete List]
» 2 Member(s) | 10532 Guest(s)
