Canadian 345 Butterfly
Morzh, I have had a couple of brand new caps fail in my years of service work. Had a guy bring a high end amp with some expensive coupling caps he wanted installed. He paid $600 for 6 caps and one failed on the first power up. Supplier gave us another no questions asked. The second one was not to long ago a 10uf 450v cap, shorted on first power up. I have always had the habit of testing every cap before installation so I know these two were good when installed.
Gregb
Canadian 345 Butterfly - by gregb - 02-21-2014, 09:51 PM
RE: Canadian 345 Butterfly - by morzh - 02-21-2014, 09:57 PM
RE: Canadian 345 Butterfly - by murf - 02-21-2014, 10:23 PM
RE: Canadian 345 Butterfly - by morzh - 02-21-2014, 10:28 PM
RE: Canadian 345 Butterfly - by gregb - 02-21-2014, 10:42 PM
RE: Canadian 345 Butterfly - by morzh - 02-21-2014, 10:49 PM
RE: Canadian 345 Butterfly - by Mondial - 02-21-2014, 11:01 PM
RE: Canadian 345 Butterfly - by gregb - 02-21-2014, 11:03 PM
RE: Canadian 345 Butterfly - by klondike98 - 02-21-2014, 11:06 PM
RE: Canadian 345 Butterfly - by gregb - 02-21-2014, 11:09 PM
RE: Canadian 345 Butterfly - by gregb - 02-21-2014, 11:10 PM
RE: Canadian 345 Butterfly - by Mondial - 02-21-2014, 11:32 PM
RE: Canadian 345 Butterfly - by klondike98 - 02-21-2014, 11:42 PM
RE: Canadian 345 Butterfly - by gregb - 02-21-2014, 11:43 PM
RE: Canadian 345 Butterfly - by Arran - 02-21-2014, 11:45 PM
RE: Canadian 345 Butterfly - by klondike98 - 02-21-2014, 11:53 PM
RE: Canadian 345 Butterfly - by gregb - 02-22-2014, 12:01 AM
RE: Canadian 345 Butterfly - by klondike98 - 02-22-2014, 12:07 AM
RE: Canadian 345 Butterfly - by Arran - 02-22-2014, 12:45 AM
RE: Canadian 345 Butterfly - by morzh - 02-22-2014, 12:52 AM
RE: Canadian 345 Butterfly - by gregb - 02-22-2014, 12:55 AM
RE: Canadian 345 Butterfly - by gregb - 02-22-2014, 01:03 AM
RE: Canadian 345 Butterfly - by Arran - 02-22-2014, 01:04 AM
RE: Canadian 345 Butterfly - by morzh - 02-22-2014, 12:53 PM
There are currently 10082 online users. [Complete List]
» 1 Member(s) | 10081 Guest(s)
