Canadian 345 Butterfly
Maybe I should check the nearest Micheal's again about coloured glue sticks, the last time I checked was about a year ago and they only had the regular kind. Maybe word got up to head office that someone was looking for colored sticks? It could also be that the Nanaimo Micheal's is just a crappy store?
Canadian 345 Butterfly - by gregb - 02-21-2014, 09:51 PM
RE: Canadian 345 Butterfly - by morzh - 02-21-2014, 09:57 PM
RE: Canadian 345 Butterfly - by murf - 02-21-2014, 10:23 PM
RE: Canadian 345 Butterfly - by morzh - 02-21-2014, 10:28 PM
RE: Canadian 345 Butterfly - by gregb - 02-21-2014, 10:42 PM
RE: Canadian 345 Butterfly - by morzh - 02-21-2014, 10:49 PM
RE: Canadian 345 Butterfly - by Mondial - 02-21-2014, 11:01 PM
RE: Canadian 345 Butterfly - by gregb - 02-21-2014, 11:03 PM
RE: Canadian 345 Butterfly - by klondike98 - 02-21-2014, 11:06 PM
RE: Canadian 345 Butterfly - by gregb - 02-21-2014, 11:09 PM
RE: Canadian 345 Butterfly - by gregb - 02-21-2014, 11:10 PM
RE: Canadian 345 Butterfly - by Mondial - 02-21-2014, 11:32 PM
RE: Canadian 345 Butterfly - by klondike98 - 02-21-2014, 11:42 PM
RE: Canadian 345 Butterfly - by gregb - 02-21-2014, 11:43 PM
RE: Canadian 345 Butterfly - by Arran - 02-21-2014, 11:45 PM
RE: Canadian 345 Butterfly - by klondike98 - 02-21-2014, 11:53 PM
RE: Canadian 345 Butterfly - by gregb - 02-22-2014, 12:01 AM
RE: Canadian 345 Butterfly - by klondike98 - 02-22-2014, 12:07 AM
RE: Canadian 345 Butterfly - by Arran - 02-22-2014, 12:45 AM
RE: Canadian 345 Butterfly - by morzh - 02-22-2014, 12:52 AM
RE: Canadian 345 Butterfly - by gregb - 02-22-2014, 12:55 AM
RE: Canadian 345 Butterfly - by gregb - 02-22-2014, 01:03 AM
RE: Canadian 345 Butterfly - by Arran - 02-22-2014, 01:04 AM
RE: Canadian 345 Butterfly - by morzh - 02-22-2014, 12:53 PM
There are currently 8757 online users. [Complete List]
» 3 Member(s) | 8754 Guest(s)
