  • 1 Vote(s) - 5 Average
A 70 cabinet
You could make a new bottom, or can you get some glue in the cracks and clamp it together until it drys? Probably take the bottom off and glue it together with clamps should work. Unless it is worse than the pictures look, If the wood is still in good condition but just coming apart I would think glueing it together should work.
A 70 cabinet - by morzh - 02-22-2014, 12:46 AM
RE: A 70 cabinet - by Warren - 02-22-2014, 02:18 AM
RE: A 70 cabinet - by klondike98 - 02-22-2014, 09:57 AM
RE: A 70 cabinet - by Jamie - 02-22-2014, 10:16 AM
RE: A 70 cabinet - by morzh - 02-22-2014, 12:56 PM
RE: A 70 cabinet - by Jamie - 02-22-2014, 02:39 PM
RE: A 70 cabinet - by morzh - 02-22-2014, 04:03 PM
RE: A 70 cabinet - by Warren - 02-22-2014, 04:30 PM
RE: A 70 cabinet - by Jamie - 02-22-2014, 05:07 PM
RE: A 70 cabinet - by morzh - 02-22-2014, 05:23 PM
RE: A 70 cabinet - by morzh - 02-22-2014, 05:41 PM
RE: A 70 cabinet - by Warren - 02-22-2014, 06:00 PM
RE: A 70 cabinet - by Jamie - 02-22-2014, 07:13 PM
RE: A 70 cabinet - by klondike98 - 02-22-2014, 08:31 PM
RE: A 70 cabinet - by morzh - 02-22-2014, 08:39 PM
RE: A 70 cabinet - by Warren - 02-22-2014, 10:52 PM
RE: A 70 cabinet - by morzh - 02-23-2014, 07:49 PM
RE: A 70 cabinet - by Warren - 02-23-2014, 08:22 PM
RE: A 70 cabinet - by Mondial - 02-23-2014, 08:29 PM
RE: A 70 cabinet - by morzh - 02-23-2014, 09:21 PM
RE: A 70 cabinet - by Warren - 02-23-2014, 10:38 PM
RE: A 70 cabinet - by morzh - 02-23-2014, 10:59 PM
RE: A 70 cabinet - by Warren - 02-23-2014, 11:52 PM
RE: A 70 cabinet - by morzh - 02-24-2014, 12:12 AM
RE: A 70 cabinet - by Warren - 02-24-2014, 01:52 AM
RE: A 70 cabinet - by Jamie - 02-24-2014, 11:50 AM
RE: A 70 cabinet - by morzh - 02-24-2014, 04:00 PM
RE: A 70 cabinet - by Warren - 02-24-2014, 04:29 PM
RE: A 70 cabinet - by morzh - 02-24-2014, 06:06 PM
RE: A 70 cabinet - by Jamie - 02-24-2014, 06:28 PM
RE: A 70 cabinet - by Eliot Ness - 02-24-2014, 06:28 PM
RE: A 70 cabinet - by morzh - 02-24-2014, 06:38 PM
RE: A 70 cabinet - by Jamie - 02-24-2014, 06:44 PM
RE: A 70 cabinet - by Jamie - 02-24-2014, 06:45 PM
RE: A 70 cabinet - by morzh - 02-24-2014, 07:21 PM
RE: A 70 cabinet - by tab10672 - 02-24-2014, 07:27 PM
RE: A 70 cabinet - by Jamie - 02-24-2014, 07:36 PM
RE: A 70 cabinet - by Steve Davis - 02-24-2014, 10:20 PM
RE: A 70 cabinet - by morzh - 02-24-2014, 10:37 PM
RE: A 70 cabinet - by morzh - 02-25-2014, 12:38 AM
RE: A 70 cabinet - by Warren - 02-25-2014, 12:48 AM
RE: A 70 cabinet - by Jamie - 02-25-2014, 06:40 AM
RE: A 70 cabinet - by morzh - 03-04-2014, 03:20 PM
RE: A 70 cabinet - by Warren - 03-04-2014, 04:11 PM
RE: A 70 cabinet - by OldRestorer - 03-04-2014, 04:35 PM
RE: A 70 cabinet - by morzh - 03-04-2014, 05:22 PM
RE: A 70 cabinet - by Warren - 03-04-2014, 05:58 PM
RE: A 70 cabinet - by Steve Davis - 03-04-2014, 06:00 PM
RE: A 70 cabinet - by Eliot Ness - 03-04-2014, 06:01 PM
RE: A 70 cabinet - by morzh - 03-04-2014, 06:24 PM
RE: A 70 cabinet - by Eliot Ness - 03-04-2014, 08:09 PM
RE: A 70 cabinet - by Steve Davis - 03-04-2014, 09:46 PM
RE: A 70 cabinet - by Art Hoch - 03-07-2014, 12:04 AM
RE: A 70 cabinet - by morzh - 03-07-2014, 12:19 AM
RE: A 70 cabinet - by Art Hoch - 03-07-2014, 12:39 PM
RE: A 70 cabinet - by morzh - 03-07-2014, 12:50 PM
RE: A 70 cabinet - by OldRestorer - 03-08-2014, 11:23 AM
Philco 91 Tuning Condenser
There are currently 8867 online users. [Complete List]
» 1 Member(s) | 8866 Guest(s)
