What wire guage to use for rewire?
You can't get much wire from the TVs made in the last 20 years or so.
Sorry for hijacking the thread, but if you don't want to spend $$$$ on a new HDTV, just pick up a CRT type television with the largest screen you can find. Well, not literally "pick" up...the larger ones weigh well in excess of 100 pounds and will require 2 people to move them.
I have a 36 inch Toshiba in the living room...it weighs 165 pounds...cost me a whopping $5 plus gasoline to pick it up (gas was cheaper last fall)...had to resolder several points on the PC board, but now it works like new again and I will use it, with a converter box, until it wears out.
What wire guage to use for rewire? - by phly guy - 06-24-2008, 11:56 AM
[No subject] - by BDM - 06-25-2008, 12:01 AM
[No subject] - by Texasrocker - 06-25-2008, 03:16 AM
[No subject] - by rghines1 - 06-25-2008, 10:18 AM
[No subject] - by phly guy - 06-25-2008, 02:04 PM
[No subject] - by Texasrocker - 06-27-2008, 12:57 AM
[No subject] - by exray - 06-27-2008, 01:14 AM
[No subject] - by phly guy - 06-27-2008, 11:53 AM
[No subject] - by Texasrocker - 06-29-2008, 02:09 AM
[No subject] - by Ron Ramirez - 07-03-2008, 10:38 AM
There are currently 8560 online users. [Complete List]
» 1 Member(s) | 8559 Guest(s)
