Philco 40-120 Restoration
Hi -
I am about to restore a 40-120 and I found the schematic on nostalgia air .com
I am trying to build an order for the replacement capacitors and hit a bump.
The schematic gives me the uf ratings for each capacitor, but it doesn't list voltages like most schematics.
I know for most caps I can use their 640V replacements, but for the electrolytic caps, I would like to be close to the original voltage ratings.
Can anyone please tell me what voltage ratings the e-caps should be?
Or - does anyone have a 40-120 schematic that has the voltages listed for the caps?
I appreciate any help you can provide.
Many thanks,
John
Philco 40-120 Restoration - by jd3 - 02-22-2014, 10:54 AM
RE: Philco 40-120 Restoration - by hsusmann - 02-22-2014, 11:37 AM
RE: Philco 40-120 Restoration - by jd3 - 02-24-2014, 12:19 AM
RE: Philco 40-120 Restoration - by Warren - 02-24-2014, 01:56 AM
RE: Philco 40-120 Restoration - by morzh - 02-24-2014, 11:32 AM
RE: Philco 40-120 Restoration - by skyscraper - 02-24-2014, 11:55 AM
RE: Philco 40-120 Restoration - by hsusmann - 02-24-2014, 12:19 PM
RE: Philco 40-120 Restoration - by jd3 - 02-24-2014, 06:50 PM
RE: Philco 40-120 Restoration - by jd3 - 02-24-2014, 06:57 PM
RE: Philco 40-120 Restoration - by vinzer - 02-24-2014, 07:18 PM
There are currently 8835 online users. [Complete List]
» 2 Member(s) | 8833 Guest(s)
