  • 1 Vote(s) - 5 Average
Philco model 70 rebuild - by Tim P.
#54
Tim, is your tube shield in place?
M R Radios   C M Tubes
Philco model 70 rebuild - by Tim P. - by TV MAN - 01-29-2014, 11:46 AM
RE: Philco model 70 rebuild - by Tim P. - by Steve Davis - 02-22-2014, 03:08 PM
Users browsing this thread: 29 Guest(s)
There are currently 10554 online users. [Complete List]
» 3 Member(s) | 10551 Guest(s)
