  • 1 Vote(s) - 5 Average
A 70 cabinet
To use the routing base with your dremel you would also need to see if they have a bit that is close to the same shape as your trim on the radio. You could get a base at the hardware/hobby store and a bit or try to shape it by hand either with the dremel or a file. Then cut 2 pieces to size with a 45 degree angle for the corner.
A 70 cabinet - by morzh - 02-22-2014, 12:46 AM
RE: A 70 cabinet - by Warren - 02-22-2014, 02:18 AM
RE: A 70 cabinet - by klondike98 - 02-22-2014, 09:57 AM
RE: A 70 cabinet - by Jamie - 02-22-2014, 10:16 AM
RE: A 70 cabinet - by morzh - 02-22-2014, 12:56 PM
RE: A 70 cabinet - by Jamie - 02-22-2014, 02:39 PM
RE: A 70 cabinet - by morzh - 02-22-2014, 04:03 PM
RE: A 70 cabinet - by Warren - 02-22-2014, 04:30 PM
RE: A 70 cabinet - by Jamie - 02-22-2014, 05:07 PM
RE: A 70 cabinet - by morzh - 02-22-2014, 05:23 PM
RE: A 70 cabinet - by morzh - 02-22-2014, 05:41 PM
RE: A 70 cabinet - by Warren - 02-22-2014, 06:00 PM
RE: A 70 cabinet - by Jamie - 02-22-2014, 07:13 PM
RE: A 70 cabinet - by klondike98 - 02-22-2014, 08:31 PM
RE: A 70 cabinet - by morzh - 02-22-2014, 08:39 PM
RE: A 70 cabinet - by Warren - 02-22-2014, 10:52 PM
RE: A 70 cabinet - by morzh - 02-23-2014, 07:49 PM
RE: A 70 cabinet - by Warren - 02-23-2014, 08:22 PM
RE: A 70 cabinet - by Mondial - 02-23-2014, 08:29 PM
RE: A 70 cabinet - by morzh - 02-23-2014, 09:21 PM
RE: A 70 cabinet - by Warren - 02-23-2014, 10:38 PM
RE: A 70 cabinet - by morzh - 02-23-2014, 10:59 PM
RE: A 70 cabinet - by Warren - 02-23-2014, 11:52 PM
RE: A 70 cabinet - by morzh - 02-24-2014, 12:12 AM
RE: A 70 cabinet - by Warren - 02-24-2014, 01:52 AM
RE: A 70 cabinet - by Jamie - 02-24-2014, 11:50 AM
RE: A 70 cabinet - by morzh - 02-24-2014, 04:00 PM
RE: A 70 cabinet - by Warren - 02-24-2014, 04:29 PM
RE: A 70 cabinet - by morzh - 02-24-2014, 06:06 PM
RE: A 70 cabinet - by Jamie - 02-24-2014, 06:28 PM
RE: A 70 cabinet - by Eliot Ness - 02-24-2014, 06:28 PM
RE: A 70 cabinet - by morzh - 02-24-2014, 06:38 PM
RE: A 70 cabinet - by Jamie - 02-24-2014, 06:44 PM
RE: A 70 cabinet - by Jamie - 02-24-2014, 06:45 PM
RE: A 70 cabinet - by morzh - 02-24-2014, 07:21 PM
RE: A 70 cabinet - by tab10672 - 02-24-2014, 07:27 PM
RE: A 70 cabinet - by Jamie - 02-24-2014, 07:36 PM
RE: A 70 cabinet - by Steve Davis - 02-24-2014, 10:20 PM
RE: A 70 cabinet - by morzh - 02-24-2014, 10:37 PM
RE: A 70 cabinet - by morzh - 02-25-2014, 12:38 AM
RE: A 70 cabinet - by Warren - 02-25-2014, 12:48 AM
RE: A 70 cabinet - by Jamie - 02-25-2014, 06:40 AM
RE: A 70 cabinet - by morzh - 03-04-2014, 03:20 PM
RE: A 70 cabinet - by Warren - 03-04-2014, 04:11 PM
RE: A 70 cabinet - by OldRestorer - 03-04-2014, 04:35 PM
RE: A 70 cabinet - by morzh - 03-04-2014, 05:22 PM
RE: A 70 cabinet - by Warren - 03-04-2014, 05:58 PM
RE: A 70 cabinet - by Steve Davis - 03-04-2014, 06:00 PM
RE: A 70 cabinet - by Eliot Ness - 03-04-2014, 06:01 PM
RE: A 70 cabinet - by morzh - 03-04-2014, 06:24 PM
RE: A 70 cabinet - by Eliot Ness - 03-04-2014, 08:09 PM
RE: A 70 cabinet - by Steve Davis - 03-04-2014, 09:46 PM
RE: A 70 cabinet - by Art Hoch - 03-07-2014, 12:04 AM
RE: A 70 cabinet - by morzh - 03-07-2014, 12:19 AM
RE: A 70 cabinet - by Art Hoch - 03-07-2014, 12:39 PM
RE: A 70 cabinet - by morzh - 03-07-2014, 12:50 PM
RE: A 70 cabinet - by OldRestorer - 03-08-2014, 11:23 AM
Philco 91 Tuning Condenser
There are currently 8797 online users. [Complete List]
» 2 Member(s) | 8795 Guest(s)
