Philco cathedrals- Where does the 19b fit in?
Very nice job! That is a beautiful radio. Give yourself a pat on the back.
Craig R.
RE: Philco cathedrals- Where does the 19b fit in? - by VntgRads - 02-23-2014, 03:27 AM
Philco 91 Tuning Condenser
There are currently 10018 online users. [Complete List]
» 1 Member(s) | 10017 Guest(s)
