Philco cathedrals- Where does the 19b fit in?
Nice job on the radio. I have to start doing something about
my cabinets... I have been leaving them alone lest I do
something bad to them...
Your $100 price was good, hard to find any cathedrals around here
anymore. Last one I got was a 70 for $135 at an antique mall
south of Rochester.
Herb S.
Ithaca NY
RE: Philco cathedrals- Where does the 19b fit in? - by hsusmann - 02-23-2014, 12:28 PM
Philco 91 Tuning Condenser
There are currently 9699 online users. [Complete List]
» 1 Member(s) | 9698 Guest(s)
