Philco Made Garbage Cans!!!!
Oil in batteries was NOT in electrolyte - it was poured on TOP the electorlyte to prevent the evaporation.
Philco Made Garbage Cans!!!! - by Phlogiston - 02-23-2014, 05:54 PM
RE: Philco Made Garbage Cans!!!! - by morzh - 02-23-2014, 07:00 PM
RE: Philco Made Garbage Cans!!!! - by Ron Ramirez - 02-23-2014, 08:21 PM
RE: Philco Made Garbage Cans!!!! - by Phlogiston - 02-23-2014, 10:14 PM
RE: Philco Made Garbage Cans!!!! - by Jayce - 02-23-2014, 10:22 PM
