Dropping net
Streaming music does not require huge bandwidth.
Have you made sure your home network is good?
It could be ISP too, you could take it up with them if you find out your home equipment is functioning properly.
Now, are you streaming from Internet or from local server?
If from Internet, could the server you stream from drop the connection?
Dropping net - by w4rtc - 02-21-2014, 05:51 PM
RE: Dropping net - by Ron Ramirez - 02-21-2014, 07:19 PM
RE: Dropping net - by Raleigh - 02-23-2014, 01:22 AM
RE: Dropping net - by Ron Ramirez - 02-23-2014, 08:57 PM
RE: Dropping net - by morzh - 02-23-2014, 09:26 PM
RE: Dropping net - by skyscraper - 02-23-2014, 09:55 PM
RE: Dropping net - by w4rtc - 02-23-2014, 10:05 PM
RE: Dropping net - by w4rtc - 02-23-2014, 10:09 PM
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4801 online users. [Complete List]
» 3 Member(s) | 4798 Guest(s)
