Dropping net
Running www.speedtest.net on your fastest computer and the streaming computer would tell you whether it's the isp or something locally.
Anything over 1.5mbit should be able to sustain a 128k music stream, as long as there isn't a lot of other traffic. Can you stream without problems from other sources?
Dropping net - by w4rtc - 02-21-2014, 05:51 PM
RE: Dropping net - by Ron Ramirez - 02-21-2014, 07:19 PM
RE: Dropping net - by Raleigh - 02-23-2014, 01:22 AM
RE: Dropping net - by Ron Ramirez - 02-23-2014, 08:57 PM
RE: Dropping net - by morzh - 02-23-2014, 09:26 PM
RE: Dropping net - by skyscraper - 02-23-2014, 09:55 PM
RE: Dropping net - by w4rtc - 02-23-2014, 10:05 PM
RE: Dropping net - by w4rtc - 02-23-2014, 10:09 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4574 online users. [Complete List]
» 1 Member(s) | 4573 Guest(s)
