Philco model 70 rebuild - by Tim P.
Threads: 562
Actually I aligned mine with no shield first.
Then I decided to realign (for some other reason) and this time did it with shield on.
Did not see any difference, but that I guess can vary from radio to radio.
Actually in the 90 the procedure calls for the shield removed when aligning IF frequency.
RE: Philco model 70 rebuild - by Tim P. - by morzh - 02-24-2014, 03:50 PM
Users browsing this thread: 29 Guest(s)
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 10289 online users. [Complete List] » 2 Member(s) | 10287 Guest(s)
