Help identifying Philco transistor from 1960's
Glad I could help...it was mostly luck! Maybe one will come up for sale on ebay or craigslist and you can pick one up.
Icon_razz
RE: Help identifying Philco transistor from 1960's - by klondike98 - 02-24-2014, 04:51 PM
There are currently 10120 online users. [Complete List]
» 1 Member(s) | 10119 Guest(s)
