37-690 questions
What bulb number does a 37-690 use for the flood lamps. The parts list only shows the complete assembly PN 38-8210 all 4 or 39-7937 single so the cross reference here http://www.philcorepairbench.com/lamps.htm can not be used.
Has anyone ever seen the speaker baffles used on a 37-690? Better yet have pictures and or dimensions, make up of the parts used.
What chassis washers and RF sub chassis rubber mounts are used?
I see no mention of them in the parts list and the descriptions here
http://www.renovatedradios.com/parts.html are too weak to trust.
Thanks
Bill
It's not what you don't know that hurts you it's what you know that's not so.
37-690 questions - by wonderwrench - 07-05-2008, 04:25 PM
[No subject] - by etech - 07-05-2008, 11:50 PM
[No subject] - by wonderwrench - 07-07-2008, 03:31 PM
[No subject] - by Ron Ramirez - 07-07-2008, 09:52 PM
[No subject] - by wonderwrench - 07-08-2008, 01:09 AM
[No subject] - by wonderwrench - 07-18-2008, 10:11 PM
[No subject] - by Ron Ramirez - 07-18-2008, 10:36 PM
[No subject] - by wonderwrench - 07-21-2008, 01:35 PM
[No subject] - by wonderwrench - 07-24-2008, 05:11 PM
[No subject] - by Ron Ramirez - 07-24-2008, 09:33 PM
[No subject] - by wonderwrench - 07-24-2008, 09:36 PM
[No subject] - by Ron Ramirez - 07-24-2008, 09:41 PM
[No subject] - by wonderwrench - 07-25-2008, 12:17 PM
[No subject] - by wonderwrench - 08-02-2008, 10:09 AM
[No subject] - by Ron Ramirez - 08-02-2008, 11:17 AM
There are currently 8133 online users. [Complete List]
» 1 Member(s) | 8132 Guest(s)
