Transformer Question?
I don't know a whole lot about high voltage transformers, but I do know Ohm's law. You can experiment, just make sure you have two transformers with matched windings.
I would guess the higher resistance would cause the voltage to fluctuate somewhat with load, but that's easy enough to test.
In the end, it's about the ratings of the transformer and Ohm's law.
Transformer Question? - by Mr Grumpy - 02-24-2014, 02:53 PM
RE: Transformer Question? - by TV MAN - 02-24-2014, 03:36 PM
RE: Transformer Question? - by morzh - 02-24-2014, 03:46 PM
RE: Transformer Question? - by klondike98 - 02-24-2014, 05:07 PM
RE: Transformer Question? - by tab10672 - 02-24-2014, 05:34 PM
RE: Transformer Question? - by morzh - 02-24-2014, 05:59 PM
RE: Transformer Question? - by skyscraper - 02-24-2014, 06:03 PM
RE: Transformer Question? - by morzh - 02-24-2014, 06:09 PM
RE: Transformer Question? - by tab10672 - 02-24-2014, 06:38 PM
RE: Transformer Question? - by skyscraper - 02-24-2014, 06:42 PM
RE: Transformer Question? - by tab10672 - 02-24-2014, 06:44 PM
RE: Transformer Question? - by skyscraper - 02-24-2014, 06:49 PM
RE: Transformer Question? - by tab10672 - 02-24-2014, 06:51 PM
RE: Transformer Question? - by skyscraper - 02-24-2014, 07:04 PM
RE: Transformer Question? - by tab10672 - 02-24-2014, 07:08 PM
RE: Transformer Question? - by morzh - 02-24-2014, 07:15 PM
RE: Transformer Question? - by skyscraper - 02-24-2014, 07:24 PM
RE: Transformer Question? - by klondike98 - 02-24-2014, 07:24 PM
RE: Transformer Question? - by morzh - 02-24-2014, 09:43 PM
RE: Transformer Question? - by Mr Grumpy - 02-25-2014, 10:08 AM
RE: Transformer Question? - by morzh - 02-25-2014, 12:17 PM
RE: Transformer Question? - by Mr Grumpy - 02-25-2014, 12:43 PM
RE: Transformer Question? - by morzh - 02-25-2014, 01:21 PM
RE: Transformer Question? - by Warren - 02-25-2014, 02:30 PM
RE: Transformer Question? - by morzh - 02-25-2014, 02:36 PM
RE: Transformer Question? - by Joeztech - 02-25-2014, 10:26 PM
RE: Transformer Question? - by morzh - 02-25-2014, 10:30 PM
RE: Transformer Question? - by Mr Grumpy - 01-18-2015, 11:55 AM
RE: Transformer Question? - by morzh - 01-18-2015, 12:20 PM
RE: Transformer Question? - by OZ4 - 01-18-2015, 01:13 PM
RE: Transformer Question? - by Mr Grumpy - 01-21-2015, 11:28 AM
