89 Cabinet
Dremel makes a 4 piece mini routing bit set that matches that cut pretty well, instead of the router base dremel makes another attachment (not sure what its called or used for) that looks like a mini router base, smaller than the actual dremel router base (you will know when you see it) that is easier to work with and hight adjustable. All sold at Loews.
89 Cabinet - by skyscraper - 02-25-2014, 12:02 AM
RE: 89 Cabinet - by Warren - 02-25-2014, 12:51 AM
RE: 89 Cabinet - by tab10672 - 02-25-2014, 01:10 AM
RE: 89 Cabinet - by OldRestorer - 02-27-2014, 10:39 AM
RE: 89 Cabinet - by tab10672 - 02-27-2014, 04:13 PM
RE: 89 Cabinet - by skyscraper - 02-27-2014, 04:39 PM
RE: 89 Cabinet - by tab10672 - 02-27-2014, 10:32 PM
RE: 89 Cabinet - by tab10672 - 02-27-2014, 10:42 PM
RE: 89 Cabinet - by skyscraper - 02-27-2014, 11:50 PM
RE: 89 Cabinet - by tab10672 - 02-28-2014, 12:25 AM
RE: 89 Cabinet - by Jake Blake - 03-10-2014, 08:23 AM
Philco 91 Tuning Condenser
There are currently 10487 online users. [Complete List]
» 2 Member(s) | 10485 Guest(s)
